Backend Log Error
Beat.Traber
in Backend Log of my MARS I find literally hundreds of messages as follows:
7/24/08 4:50:26 PM CEST Error ./device_monitor Thread 41372592:Device monitor trying to add entry with interfaceId = 0 to pn_report_result table. Skipping.
Any suggestions how I can identify the device which causes this error?
Actually it seems you are hitting another bug :)
CSCsr13959 Bug Details
MARS- Log entry filling up backend logs
Symptom:
If cu has hit bug CSCsm98109 and has upgraded to x.3.4 or above then the log that was created in the resolution of this original bug will fill up the backend logs with thousands of the following log:
Conditions:
Must be hitting original bug CSCsm98109 and have upgraded to x.3.4 or higher.
Workaround:
None
Farrukh
14 Replies 14
aghaznavi
Level 5
Level 5
This error looks like a high CPU usage , it might be impact on the performances of the system.
http://www.cisco.com/en/US/docs/security/security_management/cs-mars/4.3/compatibility/local_controller/dtlc43x.html
No, CPU usage is in the range from 5% to 15% which I find quite moderate. Our system seems to run fine.
My initial question was, how I can find out the source of this error message. I have about 300 devices in our system - and one of them seems to cause this error. And I haven't the time to check every single one
Please check the logging messages below/above the message you posted. If this is the only one, try re-adjusting the logging levels in MARS. (Admin >> System Maint >> Logging Levels). Do it for "device_monitor".
Farrukh
Please note, that it is an error message. I don't find it useful to suppress error messages in logfiles.
I think Farrukh is suggesting that you try increasing the verbosity of the logs for the device_monitor process. By default, it will be at INFO level. You can increase to DEBUG or TRACE.
Oh, right, sorry, that was a misunderstanding on my part. Will have a go at this!
Thanks for the clarification Mathew, I was really perplexed by the response (and rating) I got. Was wondering if it was a communication issue :)
Farrukh
Unfortunately I'm getting nowhere. I've increased the level of the device_monitor process to 'trace' (which is said to be more verbose than 'debug'). Now I'm getting this output:
8/8/08 12:58:30 PM CEST Trace ./device_monitor 0045:Received message of type 100
8/8/08 12:58:40 PM CEST Trace ./device_monitor 0045:Received message of type 100
8/8/08 12:58:50 PM CEST Trace ./device_monitor 0045:Received message of type 100
8/8/08 12:59:00 PM CEST Info ./superV Thread 88800176:Earliest event time in filled DB partitions: 1212561551
8/8/08 12:59:00 PM CEST Info ./superV Thread 88800176:Available space in /pnarchive partition: 70297 M
8/8/08 12:59:00 PM CEST Trace ./device_monitor 0045:Received message of type 100
8/8/08 12:59:00 PM CEST Info ./superV Thread 88800176:/pnarchive/tmp used 97 M disk space
8/8/08 12:59:10 PM CEST Trace ./device_monitor 0045:Received message of type 100
8/8/08 12:59:10 PM CEST Info ./pnparser Thread 2845285296:
8/8/08 12:59:11 PM CEST Info ./pnparser 2016:message rate: 821.789978 msgs/sec, total: 900000 msgs, total avg rate: 772.230698 msgs/sec
8/8/08 12:59:20 PM CEST Trace ./device_monitor 0045:Received message of type 100
8/8/08 12:59:30 PM CEST Trace ./device_monitor 0045:Received message of type 100
8/8/08 12:59:40 PM CEST Trace ./device_monitor 0045:Received message of type 100
8/8/08 12:59:48 PM CEST Info ./pnparser Thread 2866265008:Netflow Shared Buffer Store EventRate: 818.804198 Running Avg EventRate: 791.871948
8/8/08 12:59:50 PM CEST Trace ./device_monitor 0045:Received message of type 100
8/8/08 12:59:51 PM CEST Info ./pnparser Thread 2876754864:Thread 1: netflow messageRate: 1323, CacheQueueSize: 0:18, eventQueueSize:2982, fireQueueSize: 0, sessionQueueSize: 12945:12993:24593, netflowQueueSize: 0
8/8/08 12:59:56 PM CEST Debug ./device_monitor Thread 106175408:----------Start Detection.
8/8/08 12:59:56 PM CEST Debug ./device_monitor Thread 106175408:Finish polling.
8/8/08 12:59:56 PM CEST Error ./device_monitor Thread 106175408:Device monitor trying to add entry with interfaceId = 0 to pn_report_result table. Skipping.
... and the previous line being repeated about 6400 times (!), and finally the following lines...
8/8/08 12:59:56 PM CEST Debug ./device_monitor Thread 106175408:Skipped writing report-result logs! Run mode is 0.
8/8/08 12:59:56 PM CEST Trace ./device_monitor Thread 106175408:Inserted 74 rows (array capacity 50000)
8/8/08 12:59:56 PM CEST Debug ./device_monitor Thread 106175408:Finish generating the report.
8/8/08 12:59:56 PM CEST Debug ./device_monitor 2017:Error waiting for the DB change semaphore, returned 4
8/8/08 12:59:56 PM CEST Debug ./device_monitor Thread 106175408:Finish storing the file.
8/8/08 12:59:56 PM CEST Debug ./device_monitor Thread 106175408:Finish Detection.
8/8/08 1:00:00 PM CEST Trace ./device_monitor 0045:Received message of type 100
8/8/08 1:00:10 PM CEST Trace ./device_monitor 0045:Received message of type 100
8/8/08 1:00:20 PM CEST Trace ./device_monitor 0045:Received message of type 100
8/8/08 1:00:30 PM CEST Trace ./device_monitor 0045:Received message of type 100
8/8/08 1:00:40 PM CEST Trace ./device_monitor 0045:Received message of type 100
8/8/08 1:00:50 PM CEST Trace ./device_monitor 0045:Received message of type 100
Previously I had the 'Monitor Resource Usage' on for the core devices, but now I switched them to 'NO'. This does not help with the amount of lines in the log. Even worse: I get the impression they're getting more and more.
Please can you let me know the MARS model and version you are running right now?
Farrukh
We use a MARS Model 110
Product Version is 5.3.5 ( 2934 )
Regards, Beat
As per the release notes, a bug similar to this syslog was fixed in 5.3.4
CSCsm98109
Resource Utilization Report shows multiple bad entries (device_monitor)
MARS Oracle database reporting 0 values on index tables.
Another one which is still an 'open caveat' is the following:
CSCsi65713
Index needs to be removed for the pn_report_result table
But this one seems to be open to Cisco employees only.
I would suggest that you proceed and open a case with TAC.
Farrukh
Symptom:
Conditions:
Workaround:
None
Farrukh
Thanks Farrukh
That's it. Exactly my case. Amazing though, that it's now in the 'fixed' status.
I'll try and open a case via our supplier.
Regards, Beat
Beat, if you thing your problem is resolved, it is always motivating to rate the post accordingly and mark the post as "Resolved". Those guys really go off the track to help us and it is our responsibility to encourage and highlight them.
Please rate this conversation as "resolved my issue" based on Farrukh's recomendations that solved your problem.
thanks.
Mohsin
