Can't console into fasthub 400
Jul 24th, 2008
Hi all. I cannot console into a fasthub 400. I have tried using ZOC and hypterterminal.
I can telnet into the hub though. do you know of anything I can try to enable the com port or other advice?
mchin345 Wed, 07/30/2008 - 14:42
  • Silver, 250 points or more
The console port on the hub provides terminal and PC access to the hub. After the hub is installed, be sure to configure the console port settings of the hub to match the settings of the terminal or PC.
These are the default settings of the hub console port:
•Baud rate default is 9600.
•Data bits default is 8.
•Stop bits default is 1.
FastHub 400 Series Installation and Configuration Guide
http://www.cisco.com/en/US/docs/switches/lan/hubs/fhub400/install_config/guide/fh4web.html
•Parity settings default is None.
