media master push to client desktop?
Jul 24th, 2008
I have a scenario that i need to have the media master bar pushed out and installed to the desktops. (end users locked out of installing it)
Any tips on how to do this?
Overall Rating: 5 (1 ratings)
espereir Mon, 08/04/2008 - 03:05
Tommer,
The MM is an IE ActiveX; you just need to copy/paste the MM into the IExplorer ActiveX folder.
a
From a PC with MM installed, go to the %windir%\Downloaded Program Files folder and copy the MM, then, go to the other desktop and paste the MM object on the same location.
Hope this helps!
Tommer Catlin Mon, 08/04/2008 - 07:21
yeah, that's I would thought also, but my client was telling me they couldnt figure it out. (whatever that meant)
Thanks much for your post though!
kevincranford Mon, 08/04/2008 - 16:35
This will not work. You can not copy from the IE folder Downloaded Program Files.
Yorick Petey Tue, 06/09/2009 - 01:05
Did you find a solution for your problem?
My customer wants to deploy the ActiveX of Media Control bar for use of Cisco PCA Webpage. Their users are not local admin so they cannot install it by themselves.
Installing the Outlook VMO does not install the ActiveX for the Webpage...
If anyone has a workaround, thank you very much.
Yorick
