LMS 2.6 DFM Errors DCRAdapter.log
Answered Question
Jul 24th, 2008
When I open DFM Device Selector I get the following error. An exception has occurred. Please check the DCRAdapter.log file. I am trying to Check off "Synchronize with Device Credential Repository". I don't know why it is unchecked. Going through the other screens in DFM I get the same errors. I am running LMS 2.6 on Windows 2003 Server SP2 with all the latest package service packs.
I opened up a TAC case which was useless. I run the Cisco ACS agent on the same box and they wont support it until it is removed. It has run on this box together for years unil recently when this all blew up. I am about to the point of a reinstall.
Attached is the log. I see the network connection failure in the log but cant figure out what is failing and where.
Correct Answer by Joe Clarke about 8 years 11 months ago
I found some details about ekrn.exe. It appears to be security-related, and it could be interfering with LMS. Can you disable this process, and restart CiscoWorks Daemon Manager?
Overall Rating: 5 (1 ratings)
Joe Clarke Thu, 07/24/2008 - 07:57
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
There may be a port conflict with this agent. Please post the output of pdshow.
sullim01 Thu, 07/24/2008 - 08:07
There is not a port conflict. The ACS agent uses ports 2000 - 2005 or something a long those lines. I can shut down the ACS service and LMS has the same issues. Attached is the PDShow
Joe Clarke Thu, 07/24/2008 - 08:11
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Please post the output of netstat -a -n -o -b.
Joe Clarke Thu, 07/24/2008 - 08:25
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
It looks like some of your daemons have either failed, or were never properly initialized. I'm also seeing this ekrn.exe process bound to a lot of CiscoWorks daemons. What is this?
Correct Answer
Joe Clarke Thu, 07/24/2008 - 08:52
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
sullim01 Thu, 07/24/2008 - 10:33
This is what I found based on your information. I checked into the ekrn.exe process which is NOD32. I just found out this application was installed a month or so ago. This was about the same time that LMS blew up. I stopped this service and LMS DFM no longer has any issues. Thank you for your help!
