interface standby on CCM
Answered Question
Jul 24th, 2008
Hi all, is there a chance to configure some standby mode on two ethernet interfaces on CCM server, I mean to connect them to different switches and in case of link failure (for example because of switch failure) the standby interface would be able to retake connectivity? Thanks
Correct Answer by Rob Huffman about 8 years 10 months ago
Hi Thomas,
Just to add a link to the good info from Chris and Jaime. CCM 4.2(1) is good;
Using the Cisco Media Convergence Server Network Teaming Driver with Operating System Version 2000.4.4
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/win_os/driver/team_244.html
Hope this helps!
Rob
Overall Rating: 4 (1 ratings)
Chris Deren Thu, 07/24/2008 - 09:07
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Yes, it is supported to configure NIC teaming in CallManager. What version of CM do you have?
Chris
Jaime Valencia Thu, 07/24/2008 - 10:05
  • Cisco Employee,
  • Hall of Fame,
    2011
just as a note this is only supported on HP servers
javalenc
if this helps, please rate
Correct Answer
Rob Huffman Thu, 07/24/2008 - 10:09
  • Hall of Fame,
    Founding Member
    2017 IP Telephony, Unified Communications
Hi Thomas,
Hope this helps!
Rob
