route-map after tunnel end point
Jul 24th, 2008
Hello Folks. I have an ASA5510 with multiple tunnels terminating into it. Some sites require a hairpin bend out into the internet after terminating, this works fine with an applicable NAT statement, however, is it possible to use a route-map to route this traffic that would normally hair pin bend out the same interface back into the internet, but rather go out through another link on another host?
Marwan ALshawi Wed, 07/30/2008 - 16:40
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
yes, you can
but not with route map because in ASA there is not route map
so u need first put the folowing command to allow the tunnel exit from the same interface where it is terminated orginally
issue the
same-security-traffic intra-interface
command in the global configuration mode
and for more configurations details use the following link will be useful for your case
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00807f9a89.shtml
good luck
Please, Rate if helpful
richardsav Sat, 08/02/2008 - 01:47
Thank you for the reply, will check out URL and let you know if it solves my problem. PS,where do I rate replies?
Marwan ALshawi Sat, 08/02/2008 - 03:30
cool :)
when u click for example on my reply
and read it
there is on the end of the post( bottom right corner) drop down manu chose the rate u find it proper for that post and click submit
good luck with your case
