Generate RSA keys with ASDM 6.1
Jul 24th, 2008
I have been looking in ASDM 6.1 for a link to generate the key pair for my ASA5510 and can't seem to find it anywhere. Can someone maybe shed some light on which section I should be looking in.
Overall Rating: 5 (2 ratings)
dhananjoy chowdhury Thu, 07/24/2008 - 11:39
follow this on the ASDM interface ...
Configuration > Device Management > Certificate Management > Identity Certificates .. then Add
Under Add a new Identity certificate click New in order to add a default key pair if one does not exists.
Then, click Generate Now.
rlewis1951 Thu, 07/24/2008 - 12:09
Thanks. It worked great. Have to find where everything is here.
rlewis1951 Thu, 07/24/2008 - 12:54
It did and I am trying to find where I can put in my Trustpoint information in this version of the ASDM as I can't find the Trustpoint in the navigation pane.
