HSRP tracks incorrectly
Jul 24th, 2008
Dear Experts,
what do you think can be a reason for this "odd" situation:
I've HSRP configured on 3550
interface vlan3
ip address 172.18.0.3 255.255.255.0
standby 3 ip 172.18.0.1
standby 3 priority 95
standby 3 track Port-channel2 5
HSRP track the Po2 interface (which is a L2 trunk): Port-channel2 is up, line protocol is up
however, tracking somehow considers Po2 being down as IP DISABLED, and decreases local priority
Vlan3 - Group 3
Local state is Standby, priority 90 (confgd 95), may preempt
Preemption delayed for at least 900 secs
Hellotime 3 sec, holdtime 10 sec
Next hello sent in 2.246
Virtual IP address is 172.18.0.1 configured
Active router is 172.18.0.2, priority 100 expires in 7.648
Standby router is local
7 state changes, last state change 9w6d
Priority tracking 1 interface, 0 up:
Interface Decrement State
Port-channel2 5 Down (IP disabled)
How come? Appreciate your advise!
-igor
Edison Ortiz Thu, 07/24/2008 - 11:48
I'm unable to duplicate your problem:
Switch#sh ver | i IOS
Cisco IOS Software, C3550 Software (C3550-IPSERVICESK9-M), Version 12.2(25)SEC2, RELEASE SOFTWARE (fc1)
Switch#sh stand
Vlan1 - Group 3
State is Standby
4 state changes, last state change 00:00:48
Active virtual MAC address is 0000.0c07.ac03
Local virtual MAC address is 0000.0c07.ac03 (v1 default)
Hello time 3 sec, hold time 10 sec
Next hello sent in 0.039 secs
Preemption enabled
Active router is 172.18.0.2, priority 100 (expires in 8.985 sec)
Priority 95 (configured 95)
Track interface Port-channel1 state Up decrement 5
IP redundancy name is "hsrp-Vl1-3" (default)
___
Can you post the show track output?
Here is mine:
Switch#sh track
Track 1 (via HSRP)
Interface Port-channel1 line-protocol
Line protocol is Up
1 change, last change 00:07:03
Tracked by:
HSRP Vlan1 3
Switch#
HTH,
__
Edison.
igorkouznetsov Thu, 07/24/2008 - 12:30
will get 'show track' in awhile
however, I've an older IOS
IOS (tm) C3550 Software (C3550-I9Q3L2-M), Version 12.1(11)EA1, RELEASE SOFTWARE (fc1)
can it be a bug in it?
I did an experiment with tracking a FE interface instead of Po, got the same result
Vlan606 - Group 9
Next hello sent in 2.124
Virtual IP address is 172.18.5.65 configured
Active router is 172.18.5.66, priority 100 expires in 9.764
10 state changes, last state change 5d02h
FastEthernet0/11 5 Down (IP disabled)
FastEthernet0/11 is up, line protocol is up
interface Vlan606
ip address 172.18.5.67 255.255.255.240
standby 9 ip 172.18.5.65
standby 9 priority 95
standby 9 track FastEthernet0/11 5
First time in my hundreds of HSRP installations..
Edison Ortiz Thu, 07/24/2008 - 12:33
I suggest upgrading the code as the newer version don't have that issue.
__
Edison.
