CTI client login error
Jul 24th, 2008
hi,
m getting this error while login to the CTI client.
23:00:05.843 lab1_CTIOS1 ctios server [7.0 07383] [CONFIGURING, CG: icm, CGPort: 42027]
23:00:05.859 [SYSTEM] SYSTEM_EVENT: SYS_CTI_SERVER_ONLINE
23:00:06.031 [SYSTEM] SYSTEM_EVENT: SYS_PERIPHERAL_OFFLINE PeripheralID = 5002
23:00:06.031 [SYSTEM] SYSTEM_EVENT: SYS_PERIPHERAL_ONLINE PeripheralID = 5002
23:00:06.156 CServiceBroker:: Loading ACMI Config complete. Start accepting clients
23:00:06.156 lab1_CTIOS1 ctios server [7.0 07383] [ACTIVE, CG: icm, CGPort: 42027, Listen
Port: 42028]
23:00:47.578 Client[00001]: HandleIO: Connection closed. (ERROR_NETNAME_DELETED),
ERROR:0x00000040.
23:00:47.609 XXX RCV CLIENT[00001]: eOnConnectionClosed
thanks..
Overall Rating: 3 (2 ratings)
david.macias Thu, 07/24/2008 - 13:33
Assuming this is a new install check your PG configuration both in config manager and in the actual server, make sure that the PG servers are configured correctly.
david
sandeep pokhriyal Thu, 07/24/2008 - 13:43
i have checked the PG in both the places and couldn't able to find any problem.
one more thing this is a lab installation and all the IPCC components are installed in the same server.
thanks for your speedy reply
Chad Stachowicz Thu, 07/24/2008 - 15:36
Are your PID for the CMPG and the CTIOS the same? They must be the exact same PID (Peripheral ID) in order to work!! It took me a long time to figure this out!
IE.
CMGP
Logical ID 5000
PID = 5000
CTIOS
Logical ID = 5001
PID = 5000
seeing from the trace that your CTIOS PID is 5002, and CMPG's are probably most commonly 5000
HTH, Please rate useful posts!
Chad
sandeep pokhriyal Fri, 07/25/2008 - 07:03
hi Chad,
Where i can change the CTIOS PID i have rerun the setup of CTIOS server and still its the same. the value that i have entered is 5001 which is the PID of my CCM.
Chad Stachowicz Fri, 07/25/2008 - 07:06
Sandeep,
Plase send me the full window of trace that you have now that you have changed the PID. Also in regesit under Cisco Systems, you can change and verify all this, and thats needs to be done!
Chad
sandeep pokhriyal Fri, 07/25/2008 - 08:05
hi Chad,
Chad Stachowicz Fri, 07/25/2008 - 12:35
do you have the CTI Server set on the CCM PG, within ICM config manager? Also I want the PG log of the client trying to log in, not the CTIOS log.
HTH,
Chad
sandeep pokhriyal Sat, 07/26/2008 - 00:55
hi Chad,
i have resolved the issue now its communicating to the right PG and the CTIOS is also showing the correct PID as 5001 which is same as CCMPG.
MDS port number in registery was same for VRU PG and CCM PG.
i just changed it for the CCM and it worked i can login to the client.
thanks for your help.
Chad Stachowicz Sat, 07/26/2008 - 15:47
No problem, I fought with this issue the first time I ever installed UCCE from the ground up, and it took me ages to figure that out.
Cheers!
Chad
waridipccbd Sun, 07/27/2008 - 00:38
hi, i'm facing the same problem where my CCMPG PID and CTIOS PID are same. As well as MDS port for VRUPG and CCMPG are different. Client can't login in the server. It's showing 'Disconnected, offline' and 'login' icon visible.
Can you help me please?
waridipccbd Sun, 07/27/2008 - 03:43
hi, thanks for the guided link. The problem is resolved, issue was at client side hostfile. Edited it to resolve the CTIOS server and it's running fine. :)
Sheraz Saeed Lodhi Tue, 06/23/2009 - 21:51
hi dears,
I am facing a little bit differnet error in CTI Client. I have installed CTIOS 7.5 and its active. but when i try to login ctios client its buttons are grayed out. I am attachig the logs also. If any one could help me.
Sheraz Saeed Lodhi Wed, 06/24/2009 - 02:05
thanks guys the problem resolved. i ran the CTIOS server setup in edit mode and disable the self certificte password.
and try to login cti client it displayed me to enter a password, i entered "cisco123" and it worked.
