07-24-2008 01:27 PM
Is it possible to install LMS on different drive than the operating system drive? We try not to install ony programs on the OS drive but rather a much larger data drive. is this possible? if not i will have to repartition drives and kill my machine.
07-24-2008 05:39 PM
I do not see why not, except the caveat "We recommend that you specify a short path for the destination folder."
07-24-2008 05:43 PM
This is possible, and will work just fine. Many customers have LMS on a separate drive from the OS. Doing so eliminates a considerable amount of writes to the system drive thus reducing the chance of possible OS corruption.
07-25-2008 08:33 AM
Thank you! i was using the typical option which chooses the directory automatically and doesn't let you change. i switched to custom and it is installing.
