Urgent LAB CCNP/CCVP BID HELP
Answered Question
Jul 24th, 2008
Hello All,
I stumbled on this offer on the web and I have been considering building my own lab for a while.
What is your take on this feature? The seller says its ideally for a CCVP which i hope to eventually pursue but am currentlly still studying to complete my CCNP. Do you think this is good for CCNP as well?
The price take is a little over $1,000 roughlly $1200 including shipping and 1 year warrantee.
Here is the specification:
2 x 2924 (IOS) Switches
Conduct 802.1Q Multi-VLAN Trunking
Inter-VLAN Routing
STP / VLAN / MLS
QOS Implementation
1 x 1924/1912 Switch
Complete Spanning Tree Loop
Non-QOS Lab Work (Internet Simulations)
1 x 3640 Router
Call Manager Express (CME) for CCVP
FULL VOIP PBX
12.4 IOS
MAX FLASH RAM
NM-2e2w
WIC-1T
2 x 2610 Routers
12.3 IOS
FireWall / IDS / VPN
2 x WIC-1T (1 per unit)
2 x 7940 Phones
VOIP to CME PBX
FULL ASTERISK PBX COPY
SIP / SCCP / MGCP
Power Cubes
All CABLES AND MODULES INCUDED
All Lab Accessories
6 CAT 5 Networking Cables
2 Serial Cross-Over Cables
Power Cords
Would you buy this?
Correct Answer by rajibchicago about 8 years 7 months ago
you will need a router with fast ethernet port for router on stick config for routing between vlans unless you use layer 3 switches, 2610 does not have one, it has only 10baseT port, i would suggest buying individual router and switches rather than buying a set. (setting up home lab piece by piece is more exciting - imho) here is a link for 2600 series router interface info:
http://www.cisco.com/en/US/docs/routers/access/2600/hardware/installation/guide/2600ch1.html
Overall Rating: 0 (2 ratings)
tperrier Fri, 07/25/2008 - 00:44
I wouldn't. 2924 switches are obsolete. Look for a 2950 instead. 1924 is even more obsolete, and they're not even running the IOS.
babatunde_sanda Fri, 07/25/2008 - 05:53
Will you say your critic of the devices stop at the switches? What about the routers? Leaving out the intended CCVP eventual pursue. Do you think they are ok for CCNP practice with the IOS they are running?
Correct Answer
rajibchicago Sat, 07/26/2008 - 18:59
babatunde_sanda Sat, 07/26/2008 - 22:46
rajibchicago, I mearnt to say thank you for the information. I requested the seller replace the 1924 to a 3524 POE switch. With the IOS on the 3640 I think I can make do (hopefully) I think it has at least 1 Fastethernet port. I actually have the ISCW and ONT left to take.
