Cisco 877W - when upgrade from 124-11.XJ3 to 124-15.T5 will not Sync :/
Jul 24th, 2008
Hello guys,
just wondering if anyone knows what's going on! When I upgrade my IOS from:
c870-advipservicesk9-mz.124-11.XJ3
TO
c870-advipservicesk9-mz.124-15.T5
i.e. the latest ios, my Cisco 877W no longer Sync with the exchange, and thus no internet.
My existing configuration is pasted below. Hope someone can have a quick look over it to point out any obvious issues.
As I say, it works fine on 124-11.XJ3 but won't after upgrade, thus i've had to revert.
Many thanks..
version 12.4
hostname CiscoB
boot-start-marker
boot-end-marker
no logging buffered
enable secret 5 @@@@@@@@
enable password @@@@@@@@
no aaa new-model
clock timezone GMT 0
clock summer-time BST recurring last Sun Mar 2:00 last Sun Oct 2:00
dot11 ssid Cisco@@@@@@
vlan 10
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 0 @@@@@@@@@@
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1 192.168.1.99
ip dhcp pool VLAN10
import all
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
domain-name YouDomain.com
dns-server 208.x.x.222
lease 4
ip name-server 208.x.x.222
ip name-server 208.x.x.220
username @@@@ privilege 15 password 0 @@@@
archive
log config
hidekeys
bridge irb
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip accounting access-violations
ip route-cache flow
no atm ilmi-keepalive
dsl operating-mode adsl2+
interface ATM0.1 point-to-point
description $ES_WAN$
ip address 78.86.@@@.@@@ 255.255.240.0
ip verify unicast reverse-path
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1500
ip nbar protocol-discovery
ip flow ingress
ip flow egress
ip nat outside
ip virtual-reassembly
ip tcp adjust-mss 1460
no snmp trap link-status
atm route-bridged ip
pvc 0/101
protocol ip 78.86.@@@.@@@ broadcast
oam-pvc manage
encapsulation aal5snap
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
switchport access vlan 10
spanning-tree portfast
interface FastEthernet3
interface Dot11Radio0
no ip address
encryption vlan 10 mode ciphers tkip
encryption mode ciphers tkip
ssid CiscoBeBox
speed basic-48.0 54.0
station-role root
antenna receive left
antenna transmit right
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.10
encapsulation dot1Q 10
bridge-group 10
bridge-group 10 subscriber-loop-control
bridge-group 10 spanning-disabled
bridge-group 10 block-unknown-source
no bridge-group 10 source-learning
no bridge-group 10 unicast-flooding
interface Vlan1
no ip address
interface Vlan10
description Internal Network
no ip address
ip nat inside
bridge-group 10
interface BVI10
description Bridge to Internal Network
ip nat inside
ip route 0.0.0.0 0.0.0.0 78.86.@@@.@@@
ip http server
ip http authentication local
ip http secure-server
ip nat inside source list 1 interface ATM0.1 overload
access-list 101 permit ip any any
control-plane
bridge 1 protocol ieee
bridge 1 route ip
bridge 10 route ip
line con 0
exec-timeout 0 0
password @@@@@
login
no modem enable
line aux 0
line vty 0 4
privilege level 15
password @@@@@@
login local
transport input telnet ssh
scheduler max-task-time 5000
ntp clock-period 17175050
ntp server 192.43.244.18
end
Overall Rating: 4 (1 ratings)
Goutam Sanyal Thu, 07/24/2008 - 22:26
  • Silver, 250 points or more
Hope you have checked BUG issue with the IOS. If so then pls do the following.
#conf t
#boot system flash flash:c870-advipservicesk9-mz.124-15.T5
ctrl^z
#wri
#reload
Hope it will work
Goutam
[pls rate if it works]
