Cisco ASA NAT Error
Answered Question
Jul 24th, 2008
In my ASA I am getting some error when I want to configure static NAT and NAT exempt configuration. I think Some miss configuration has been done.
The error msg given below..
Firewall-ASA-02(config)# static (inside,outside) x.x.x.12 10.138.77.54 netma$
INFO: Global address overlaps with NAT exempt configuration
Firewall-ASA-02(config)# no access-list nonat extended permit ip 10.138.77.0 255.$
INFO: Outside address overlap with static NAT configuration
Plz help to reslove this issue..why i am getting this type of error msg.
som
Correct Answer by Marwan ALshawi about 8 years 7 months ago
as i see ur config the following line not sure if u need it if not try to REMOVE it and let me know
access-list nonat extended permit ip any 10.138.77.192 255.255.255.224
i think the following one too, !
access-list nonat extended permit ip any 10.138.74.64 255.255.255.192
good luck and let me know
Overall Rating: 5 (1 ratings)
Marwan ALshawi Fri, 07/25/2008 - 00:52
ok
now with these config dose the ASA working ok?
and when u get this errors?
can u put the lines that u wanna add and u getting errors when adding them
somnath21 Fri, 07/25/2008 - 01:00
I am getting error whnever I try to add a new STATIC NAT and NAT EXEMPT.
plz find the eeror msg..
Firewall-ASA-02(config)# static (inside,outside) x.x.x.25 10.138.77.62 netmask 255.255.255.255
INHYD-ASA-02(config)#access-list nonat extended permit ip 10.138.77.0 255.255.255.0 10.10.15.0 255.255.255.0
Regerds,
som
Correct Answer
Marwan ALshawi Fri, 07/25/2008 - 01:15
somnath21 Fri, 07/25/2008 - 01:40
I have removed this two lines but same error msg coming.I am getting the same error msg during removing aslo and after removing when tried to add a new exempt.
Marwan ALshawi Fri, 07/25/2008 - 01:44
remove them
save ur config
reload then try again
u have to reload after changing nat and nat policies
