Cat2960: FastEthernet does not come up - 1 interface resets
Jul 24th, 2008
Hi everybody.
Our AIX-Team installed a new Server, which has problems getting the Management-Interface up. We tried switching cables and switching ports, no success. Not good, but nothing special.
But what I really don't get is interface resets counter in the show interface-output:
n99903-ms02#clear counter
Clear "show interface" counters on all interfaces [confirm]y
[power on server]
n99903-ms02#sh int fa0/23
FastEthernet0/23 is down, line protocol is down (notconnect)
Hardware is Fast Ethernet, address is 0019.065b.a019 (bia 0019.065b.a019)
Description: s002fa
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
Keepalive set (10 sec)
Auto-duplex, Auto-speed, media type is 10/100BaseTX
input flow-control is off, output flow-control is unsupported
Last input never, output never, output hang never
Last clearing of "show interface" counters 00:00:34
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicast)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
n99903-ms02#sh run int fa0/23
Building configuration...
Current configuration : 207 bytes
interface FastEthernet0/23
description s002fa
switchport access vlan 12
no logging event link-status
mls qos trust dscp
no snmp trap link-status
spanning-tree portfast
spanning-tree guard root
end
The counter stays the same for several hours - just the interface reset in the first second. The Event does not produce any log-entry.
Is there any clear interpretation of a link, which is notconnect, but, has no packets in or out, but starts with an Interface reset? Can we blame the Server-NIC for sure, or is there perhaps a misconfiguration somewhere? We have the same behavior on all 4 interfaces of the Server, so before I accuse the Hardware I prefer to be sure, that it is not a fault on the network-side...
thx in adanvace for any hints
greetings from berne, switzerland
stefan mueller
Overall Rating: 3 (1 ratings)
lgijssel Fri, 07/25/2008 - 01:27
  • Red, 2250 points or more
Hello Stefan,
Determining if it is a failure on the network-side can best be done by connecting another device to the "unwilling" switchport. If that does not result in a link either, you may have a defective port.
Also be sure to check the overall cable length and any patches it may contain.
regards,
Leo
