ASA 5510 Internet Problem
Jul 24th, 2008
Hi guys, I have a dmz network in the company I worked. A private network is connected to the DMZ interface of ASA 5510. I notices that every morning I have to issue the "clear xlate" command in the IOS so that computers can connect to the Internet.
Can you help me in fixing this guys? Please.... Thanks....
helios999 Fri, 07/25/2008 - 18:41
Hi, thanks for the reply. The xlate timeout was set to 3:00:00. Is it just ok? I was using NAT but for less than 10 IP addresses.
What you think is the problem? Do I still have to post the config?
helios999 Sun, 07/27/2008 - 23:54
Hi, I posted the config of our ASA 5510 here. Please kindly check on it. Just this morning I have to issue the "clear xlate" command again so I can access the Internet from the DMZ interface of the Firewall.
I will wait for your reply. Thanks.
