IME, Events OK, Config no workin?!?!
Jul 25th, 2008
I've got something weird happening with IME, I've just installed it on a customer server (win2k3), all the services start fine, I can login, add my sensors, view the sesnor health and view all events just fine.
As soon as I hit the "configuration" button to view and change policies, I get an error message saying to check the error console... below is what's in the console... any ideas?
java.io.EOFException: Unexpected end of ZLIB input stream
at java.util.zip.InflaterInputStream.fill(Unknown Source)
at java.util.zip.InflaterInputStream.read(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLEntityManager$RewindableInputStream.read(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLEntityManager.setupCurrentEntity(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLVersionDetector.determineDocVersion(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at org.jdom.input.SAXBuilder.build(SAXBuilder.java:453)
at org.jdom.input.SAXBuilder.build(SAXBuilder.java:770)
at adm.a(DashoA2*..:65)
at pv.a(DashoA2*..:827)
at ab2.a(DashoA2*..:1449)
at adh$bf2.a(DashoA2*..:251)
at adh$bf2.run(DashoA2*..:205)
at EDU.oswego.cs.dl.util.concurrent.PooledExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
java.lang.NullPointerException
at pw.<init>(DashoA2*..:114)
at pv.a(DashoA2*..:828)
at ow$a4d.a(DashoA2*..:583)
at adh$bf2.a(DashoA2*..:252)
I've tried changing ime.ini so that IME uses the latest copy of JAVA (rather than the version supplied) but no joy.
Any further help would be appreciated.
Cheers,
Nick
