ASA VPN client question
Answered Question
Jul 25th, 2008
Hello.
I have a question about a connection between an asa5505-sec-bun-k9 (that acts as Easy VPN client) and a EASY VPN server.
The connection with the Easy VPN server is OK but I cannot more connect to internet and create VPN connections to my ASA5505 when I enable the feature.
Is this a normal condition with Easy VPN Client enabled?
Correct Answer by Marwan ALshawi about 8 years 9 months ago
cool
please, Rate if helpful
Overall Rating: 5 (1 ratings)
Marwan ALshawi Fri, 07/25/2008 - 02:45
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
u need to do split tunneling on ur vpn server and apply it to the vpn client config on the vpn server that encypt only traffic destined to the server side pravite network
lets say the private network behind the vpn server is 192.168.1.0/24
so make a standard ACL
access-list split standard permit 192.168.1.0 255.255.255.0
group-policy [ur grop policy name] attributes
split-tunnel-policy tunnelspecified
split-tunnel-network-list value split
then when u connect from the easy client only traffic to 192.168.1.0 will go through the tunnel other traffic will not be part of encrypted traffic
good luck
Rate if helpful
Correct Answer
Marwan ALshawi Fri, 07/25/2008 - 05:39
cool
