BGP: Advertising Aggregate and More-specifics
markopstc
I'm looking for the solution that will advertise aggregate and more-specific prefixes.
Example:
R1 (AS100) advertises 172.16.0.0/23 -> ISP1 AS200 (primary link)
R2 (AS100) advertises 172.16.0.0/23 -> ISP2 AS300 (secondary link)
Now I'd like to advertise 172.16.1.0/24 so it uses R2 as ingress/egress point for all traffic as primary link and still use the /23 aggregate.
Please let me know if you need more info.
Marko
9 Replies 9
Edison Ortiz
172.16.1.0/24 is on R2's routing table?
If not, you need to make an entry in R2's routing table in order to advertise such route in BGP.
One way of doing it:
ip route 172.16.1.0 255.255.255.0 null0
access-list 1 permit 172.16.1.0 0.0.0.255
route-map NET172
match ip address 1
router bgp 100
redistribute static route-map NET172
____
If 172.16.1.0/24 is on R2's routing table, you can use the unsuppress-map with BGP.
http://www.cisco.com/en/US/docs/ios/iproute/configuration/guide/irp_bgp_basic_net_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1055483
HTH,
__
Edison.
Please rate helpful posts
Hello Edison,
Thanks for the prompt reply.
Yes, R2 has this network in it's routing table (subinterface IP is in the subnet) and is advertising the network to its iBGP peers.
I'm looking at the moment at the unsupress-map option.
One more thing, at the moment there's a NULL route for /23 on both routers with network command for this supernet:
network 172.16.0.0 255.255.254
My question is whether I have to split this now into:
network 172.16.0.0 255.255.255.0
network 172.16.1.0 255.255.255.0
aggregate-address 172.16.0.0 255.255.254.0 (with unsupress-map)
On both routers?
Marko
The NULL route is created by the aggregate command. Don't be concerned about that.
Just use the unsuppress-map on R2 and this is done at the neighbor statement level, not during aggregation.
Leave the aggregation as is, then unsuppress:
route-map NET172
match ip address 1
router bgp 100
neighbor x.x.x.x remote-as xxx unsuppress-map route-map NET172
Edison,
Unfortunatelly I haven't found unsuppress or similar option on R2 (it's non Cisco device and has aggregate suppress only). Maybe there's some other option for this purpose, too? Shall I split the supernet in /24 blocks under the BGP config?
I've noted on public route server that the network is being aggregated by R1 (Cisco) and both routers are advertising aggregated and more-specific routes to their peers.
Marko
How are you planning to split after an aggregate?
You need to be able to aggregate all routes with the exception of the subnet in question.
Being you are dealing with a non-Cisco device, makes it hard to offer any suggestion as I don't know the limitation you may face with the BGP config on such device.
The unsuppress-map was designed for the task at hand.
__
Edison.
Edison,
Thanks for your help. Please advise on the following:
Plan is to segregate larger prefix (/20) into smaller blocks (21 to 24) that will use different peers in both directions, but still have redundancy in case one of the links fails.
If I make smaller subnet blocks out of /20 using network command - prefixes are not being propagated into the global BGP table, although are advertised to peers.
What am I missing here? Enclosed is the config.
R1 CONFIG (AS100):
no synchronization
no bgp fast-external-fallover
bgp log-neighbor-changes
network a.b.c.d mask 255.255.240.0
neighbor a.b.c.d remote-as 200
neighbor a.b.c.d prefix-list EXPORT out
neighbor a.b.c.d route-map SET_PREF out
neighbor b.c.d.e remote-as 100
neighbor b.c.d.e prefix-list FROM_R2 in
maximum-paths 4
no auto-summary
ip prefix-list EXPORT seq 5 permit a.b.c.d/20
route-map SET_PREF permit 10
set local-preference 100
ip prefix-list FROM_R2 seq 5 permit a.b.c.e/24 le 24 (subnet from the /20 supernet)
ip prefix-list FROM_R2 seq 10 deny 0.0.0.0/0 le 32
ip route a.b.c.d 255.255.240.0 Null0 120
R2 CONFIG (AS100):
no synchronization
neighbor a.b.c.f remote-as 300
neighbor a.b.c.f prefix-list EXPORT out
neighbor a.b.c.f route-map SET_PREF out
neighbor b.c.d.f remote-as 100
neighbor b.c.d.f route-map SET_ASPATH
maximum-paths 4
no auto-summary
access-list 1 deny a.b.c.e 0.0.0.255
access-list 1 permit any
route-map SET_ASPATH permit 10
match ip address 1
set as-path prepend 100 100 100 100
route-map SET_ASPATH permit 20
set local-preference 200
Marko
But R2 isn't sending a subnet, it's sending an aggregate route. The prefix-list won't match the incoming route.
__
Edison.
Please advise on the subnetting issue, seems to be more important than configuration I've mentioned.
As soon as split this /20 into longer prefixes (e.g. 2x/21) the complete supernet gets lost. Since I haven't done this in the past, is there some procedure for announcing new/longer prefixes or my upstream provider is using prefix or similar list and is blocking these prefixes (they are being advertised to the peer)?
Marko
lgijssel
Level 9
Level 9
Start with adding network 172.16.1.0 mask 255.255.255.0 to AS100.
Then create a distribute list that allows 172.16.0.0/23. Apply this to the neighbor config on R1.
Secondly create a list that allows both 172.16.0.0/23 and 172.16.1.0/24. Apply this to the neighbor on R2.
Verify that the route is indeed advertised by using:
sh ip bgp nei advert
The neigbor router may again summarize this network but the route for 172.16.1.0/24 should pop-up in the routing table.
regards,
Leo
