adignan Fri, 07/25/2008 - 12:45
  • Blue, 1500 points or more
What version of ICM are you running?
Only the Logger and AW service log on as a domain user ID.
First, take the servers off the current domain.
Then join them to the new domain.
Run the ICM domain manager utility to create the Root, Facility and Instance.
Try and keep the Facility and Isstance names same as before.
Re run the ICM setups from C:\icm\bin\ICMSetup.exe
