network slowness between vlans
Jul 25th, 2008
I have a server that goes through a switch asa switch then a pc. The server and PC are on two different subnets (vlans). I can ping and do a traceroute fine, but if If try to put a large file from the server to the PC it starts but then the transfer dies about 1/2 way through the transfer. Any help or thoughts would be appreciated.
lgijssel Fri, 07/25/2008 - 05:29
What do you mean by "switch asa switch" ?
Is there an ASA in the path as well?
Also, can you please include a diagram.
ralphcarter Fri, 07/25/2008 - 07:16
You need to find out where the problem resides.
1. Attach a pc to the 3750G switch and do same transfer to server.
2. Attach a a different pc to the 3560 and do same transfer.
3. Attach a pc to the 3750g and do a tranfer from PC to PC.
4. Is the Server connected to a SAN?
5. Check interface statistics, errors, "show proc cpu"
6. Check controller statistics, "show controllers ethernet-controller gigabitEthernet 1/0/1"
7. Check firewall logging and run a debug.
wplantier Fri, 07/25/2008 - 09:05
It looks like UDP port 138 is being discarded
7 Jul 25 2008 12:47:03 710005 UDP request discarded from to Dev_Remote_users_212:
We have a rule in place that allows all ip to to I dont understand why the broadcast is being blocked.
