dhananjoy chowdhury Fri, 07/25/2008 - 11:39
  • Silver, 250 points or more
yes, it supports management access using SSH or HTTPS... you have to use the command "vpnclient management tunnel" . For configuration check here
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/ezvpn505.html#wp1001074
if you want to manage the Easy VPN server remotely from behind the easy vpn hardware client then
you need to give the command "management-access inside" on th easy vpn server
marcozambon Sun, 07/27/2008 - 22:11
I want to connect to the lan behind the firewall and not only manage the firewall. I understand that if I enable the Easy VPN client (acting as an VPN client hardware) there are no more possibilities to enable VPN server capability (using VPN client software on the remote side).
