UC520 Live Record
Answered Question
Jul 25th, 2008
Hi to all,
I have a new UC520, I upgrade CME and CUE to last IOS available, all works fine (voicemail, tranfer, etc), but I want to configure the "Live Record" feature.
I follow this guide and it seems easy:
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel3_1/administration/guide/voicemail/12advVM.html#wp1025665
no problem no error during configuration, but does not work!!!
What I have to configure more???
Somebody can show me a correct and complete configuration?
When I try to make the conference, and I call the pilot number (998) I obtain the busy (error) tone. (The conference between phones works)
Why?
Thank you very much
Augusto.
Correct Answer by rob.huffman about 8 years 5 months ago
Hi Augusto,
Did you configure DN 998 in CME with Call Forward All to the CUE Pilot #? It seems like this is missing;
You can only enable the live-record feature globally for Cisco Unity Express; you cannot enable it on a per-user basis. To initiate a live-record session, users conference to an extension configured as call-forward-all on Cisco Unified Communications Manager or Cisco Unified CME and is setup to forward all incoming calls to the voice mail pilot number.
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
rob.huffman Fri, 07/25/2008 - 05:48
Hi Augusto,
Hope this helps!
Rob
a.crippa Fri, 07/25/2008 - 05:59
ok resolved, I dind't configure voicemail number on Call-forward-all of ephone-dn.
Augusto.
rob.huffman Fri, 07/25/2008 - 06:09
Hi Augusto,
You are most welcome :) Glad to be of some small help here.
Take care,
Rob
INHO CHOI Thu, 11/04/2010 - 15:39
Hi Augusto,
I am not sure you are going to read this post or not.
Anyway, if you create a special EPHONE-TEMPLATE then you can control each ephone user.
So you can deploy a template for non-LIVE-RECORD users and also deploy a template which is having LivRcd softkey for LIVE-RECORD users.
I am sorry about this short post. I hope that this is a bit helpful for you.
Cheers.
