07-25-2008 05:38 AM - edited 03-03-2019 10:54 PM
Will HSRP work on SUP(Supervisory engine) level?
or we can only use on switch level???
07-25-2008 05:45 AM
Are you referring to hybrid CatOS/IOS? HSRP is a layer 3 protocol, so it will only work on a layer 3 interface. In hybrid mode, this means on the MSFC level.
If I'm off base, please clarify the situation.
R.
07-25-2008 05:54 AM
situation is that,we have to use HSRP on our two 6513 switch and in that only one SUP engin available per switch.so how we can use HSRP here ? we have to use HSRP on switch or on SUP?
07-25-2008 08:07 AM
So if you have a trunk between the switches and your vlans span both switches, you can absolutely turn on HSRP in the VLAN interface in the IOS portion. We do this all over our enterprise. Here's a config snippet:
Primary HSRP node:
interface Vlan10
description Server Vlan
ip address 1.1.1.2 255.255.255.0
standby 100 ip 1.1.1.1
standby 100 priority 110
standby 100 preempt
Secondary HSRP node (2nd 6509):
interface Vlan10
ip address 1.1.1.3 255.255.255.0
standby 100 priority 105
standby 100 preempt
That will allow the default gateway (1.1.1.1) to fail between the two VLAN interfaces on separate 6509s.
Let me know if you need further clarification.
R.
