htarra Thu, 07/31/2008 - 13:53
  • Bronze, 100 points or more
This should be pretty simple. To do this go to the specific DN and set the call forward (internal or external) to the desired destination. However you must be cautious about one thing..Looping!
Jaime Valencia Thu, 07/31/2008 - 15:00
  • Cisco Employee,
  • Hall of Fame,
    2011
CUCM is configured to only perform 12 jumps by defaults before returning a busy signal so looping is really not a concern
java
if this helps, please rate
Hossain Ahmed A... Fri, 08/01/2008 - 01:16
My question was different. I am describing it below:
suppose there are 5 DN 21,22,23,24 and 25. My DN is 26. On my DN I set call forwardal to my mobile. Now if call come from any dn call will be forward to my mobile but I want to make the DN specific like only call from 25 go to my mobile and others will be ignored.
Marwan ALshawi Fri, 08/01/2008 - 04:06
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
through what i know it will not be possiable with normal config
however there is a play around u can do it if u find it convenient
as u mention u want for example DN 25 when call u on DN 26 be forwarded to your mobile phone
let say ur mobile phone is 5678910 and the access code for outside calls in us system is 9
so what u can do
make partition let say called P1 and make new CSS lets say called CSS1
in CSS1 pput all the partitions that are currently included in the current CSS of DN 25
in addetion to that add partition P1 u have just created
then creat a translation-pattren
make the matching of translation pattren as ur number in our example 26
and in the Called Party Transformations
make the Called Party Transform Mask
as ur mobile with outside code
let say in ur CUCM u have a pattren that let u call mobile phons like
9.XXXXXXX
so in our example as we mention ur mobile as 5678910
so the number u have put in the Called Party Transform Mask is 95678910
and the important thing to make this works fine make the translation pattren partition ( P1)
and give this partition the proper CSS that allow it to make outside call
in this case only DN 25 have access to this translation pattren and whenever DN 25 dial ur DN as 26 will be forwarded inother words translated to ur mobile phone
when u want to stop this
u can either remove this translation pattren or remove the P1 partition from DN 25 CSS
good luck
please, rate if helpful
