ACE: URL as Rservers
Jul 25th, 2008
Hi Colleques,
I'm interested in directing traffic to URLs.
Say www.mydomain.com/emails/
which has many real servers that I do not know where they are and of many there are.
Is this a type of destination URL based load balancing.
I'm interested in an earlier conversation (2007) that mentions URL based loadbalancing.see "Posted by: dustin.black - Nov 27, 2007"
additionally I have a separate question.
If I configure SSL initiation, can I then route the traffic, but not load balnce the traffic as at present I do not have statically coded rserver IP addresses, but a means to find the addresses on the fly.
Syed Iftekhar Ahmed Fri, 07/25/2008 - 11:14
  • Blue, 1500 points or more
You can only redirect (send 301/302s)to a URL.
To loadbalance you need Real server IPs.
Syed
s.srivas Mon, 07/28/2008 - 08:02
Thanks Syed,
Can I only do SSL Initiation and then route that traffic, not loadbalance that traffic as I will only know the destination address from the packets received.
Sinnathurai
Syed Iftekhar Ahmed Mon, 07/28/2008 - 22:28
One option to achieve this would be to use "transparent" server farm. In transparent server farm Traffic is not translated. It will be intercepted by ACE and then ACE will initiate an SSL session to the Same Server.
Only problem is that you will have to recieve clear text traffic on port 443. This way ACE will recieve clear text traffic for x.x.x.x:443 and the it will encrypt it and will send it Encrypted to x.x.x.x:443.
One option to bypass this requirement could be to use a NAT device to translate destination port to 443 from port 80 (before traffic hits ACE).
Syed Iftekhar Ahmed
