outside incoming calls forward problem on UC520
Jul 25th, 2008
My UC520 is registred in SIP server, I can call and receive calls, but for all incomingw calls it's impossible to forward these calls to another phone number (noan forward, busy forward, and all forward).
But local forwards works well
Thanks in advance for help.
ivillegas Thu, 07/31/2008 - 10:50
Can you post the following:
show version - from the UC520
show run - from the UC520
How do calls flow through your network?
How is the UC520 connected to the PSTN?
The output of 'debug voip ccapi inout' when you try to make such a call.
mohammed.guertit Fri, 08/01/2008 - 00:33
Thanks for help, but I am sorry, I can't give you all informations asked because I can't access to the UC520 remotly, next week
Best ragrds.
maharris Fri, 08/01/2008 - 08:23
OK, I think I know your problem, we are just running into this on our network - in our case, the calls from the calls coming into the Sip network have to come from numbers that are registered peers on the Sip server, and when you forward, that is not the case. I came up with a translation scheme yesterday that should address this, it will leave untouched any number that matches a peer number, and if it does not match, it will stuff it with a calling number that will work. You lose the actual calling number, but it will at least work, and your users will come to recognize that it is at least a forwarded call..
For this example, say that your registered numbers are 515 555-5100 to 5199:
Voice translation-rule 100
rule 1 /\(^51555551..\) /\1/
rule 2 /.*/ /5155555100/
voice translation-profile callerid
translate calling 100
voice-port x/x:23
translation-profile outgoing callerid
I hope this helps!
Mary Beth
