prefix all numbers with 403
Jul 25th, 2008
Any way so that I don't have to prefix all my numbers with 403?
For eaxmaple as in 403-233-1234.
Jaime Valencia Fri, 07/25/2008 - 13:59
for called number? calling numbers? callback?
please provide more details
if this helps, please rate
cisco999kid Mon, 07/28/2008 - 05:06
It is calling out from my phone.
A few months ago, the government changed the rule so that all called numbers must sart with an area code. Old = 123-1234, new way = 403-123-1234. Any way to automatically do the 403, so it doesn't have to be input every time? Thanks.
logicaltrc Mon, 07/28/2008 - 15:48
Create a translation rule to translate all DN's to the full 10digit number by adding the area code.
voice translation-rule 1
rule 1 /^\(123....\)$/ /403\1/
voice translation-profile xlate_out
translate calling 1
Apply the translation to each and every outbound dial peer.
dial-peer voice 10 pots
translation-profile outgoing xlate_out
destination-pattern 9[2-9]......
port 0/0/0:23
cisco999kid Tue, 07/29/2008 - 05:03
Sorry, I am still in the stoneage regarding such programming language. Could you please kindly point me to soem manual where I can learn a bit more on:
a) where to put this code?
b) need compiling?
c) does this code apply to all DN's stored in the system? all I want is to dial 123-4567 when I punch in the DN without 403, not applying to DN's in storage or memory. will this code do the trick?
Thanks in advance.
cisco999kid Tue, 07/29/2008 - 09:51
Here is challenge for you. I am not good in Java or CUCM. Any way of accomplishing the goal? Or is it totally & definitely hopeless.
Jaime Valencia Tue, 07/29/2008 - 09:55
java????? this is not a programming language, it's a CLI interface and you need to type in the commands. links i posted have all the info.
and for CUCM there are also several guides you can look at
the way to accomplish this is to read the documentation and try it
