ASA5505- Active/Stdby config suggestion
Jul 25th, 2008
  • Gold, 750 points or more
Hi All,
I have ASA 5505 with IOS 7.2 (3) -Security plus license acting as EZVPN server for few deployments.
Iam planning to add another similar unit as standby (secondary)
Current config (removed VPN related config)
interface Vlan1
nameif inside
security-level 100
ip address 10.50.25.10 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 64.195.21.236 255.255.255.248
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3-4
Shutdown
route outside 0.0.0.0 0.0.0.0 64.195.21.233 1
Please find the attached and suggest if any additional config needed for adding the second ASA + any specific sequence of connection between the units.
Thank you in advance for your suggestions.
MS
Overall Rating: 5 (1 ratings)
mvsheik123 Fri, 07/25/2008 - 16:10
Hi all,
I just realized that I uploaded wrong file. I don't need any config on the Stdby ASA except for the 'failover'. Based on that please suggest on config for primary and any sequence suggestions.
Thank you
MS
sundar.palaniappan Sat, 07/26/2008 - 18:32
  • Green, 3000 points or more
MS
Failover configuration looks good on both units. As you correctly pointed out the only configuration that's required on the standby unit is the failover configuration.
Verify VLAN 1 and 2 interfaces are showing as monitored interfaces and the status should be normal in the 'show failover' output.
Sundar
mvsheik123 Mon, 07/28/2008 - 07:58
HiAll,
The failover establised with no issues. But some how the 5505 acting as EZVPN server no seeing any IKEs. The debug showing:
[IKEv1]: IKE receiver: Local unit is failover enabled but is not currently active.
On the Remote cleint end ASA: the isakmp sa:
State: AM_WAIT_MSG2.
Everything working fine before the failover unit added.
Please suggest.
Thank you
MS
mvsheik123 Mon, 07/28/2008 - 12:16
I figured this one out. The reason being Cisco5505 does not let Failover to work while Easyvpn server config exists.
Failover first and then Easyvpn config addition..working fine.
Thank you
MS
