Disabling phone directory lookup
Answered Question
Jul 25th, 2008
I have built up phone to be used during video arraignment by in-custodies. I want to disable all of the button funtions. I have already set up the phones in their search spaces to auto dial it's sister phone. At the bottom of the phone configuration page I have disabled "Settings Access" and I am not able to see the network settings but I can still search the phone directory to see other extensions.
I've search the Cisco site and google but I am having problems finding a clear solution. Does anyone know of a solution? We are using CCM 4.1(3)sr7 and the phones in use for this project are 7911 and 7912.
Thank you.
Correct Answer by Rob Huffman about 8 years 11 months ago
Hi Matt,
For the phones in question you can enter a "fake" url under the Phone config page (Directory)
Cisco IP Phone - External Data Locations (leave blank to use default)
Directory Url
http://blah/CCMCIP/xmldirectory.asp
Hope this helps!
Rob
Overall Rating: 4.5 (2 ratings)
Correct Answer
Rob Huffman Fri, 07/25/2008 - 09:57
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Matt,
Directory Url
Hope this helps!
Rob
Rob Huffman Fri, 07/25/2008 - 12:56
  • Hall of Fame,
    Founding Member
Hi Matt,
Good stuff! Glad this worked for you.
Take care and thanks,
Rob
Mike Bullough Thu, 03/04/2010 - 15:32
This seems to work fine on the 7912 but not on the 7911. We are using CUCM 7.13b. Still looking for help on this.
Mike Bullough Fri, 03/05/2010 - 12:29
Thank you! That worked great. Just what I was looking for.
Mike
