dual vlan on a single link
Jul 25th, 2008
I have a bit of a challenge. I have installed a point-to-point microwave link and assigned it ip of 172.24.0.x/29 on each node. At the PE (router) i configure to subinterfaces one for Vlan22(internet) and a second for vlan 33 (Management). Vlan 33 covers the 172.24.0.x/29 subnet while vlan 22 covers the 6x.17x.x.x/29 subnet for the client. The issue is I configure a trunk on the switch port to allow vlan 22, 33. however assigning a host the 6x.17x.x.x ip i cant ping my gate way on the same subnet in vlan 22.
Please help
dhananjoy chowdhury Fri, 07/25/2008 - 10:17
what I understand about your setup is
SW1 and SW2 both has VLAN's 33 and 22 configured
Now, if this is the case did you configure your router's in bridge mode?
segunoyeleke Fri, 07/25/2008 - 10:24
ok here is the setup
the issues are
1. i configure a trunk to pass vlan 22,33 no problems if is a router or can do tagging
2. however connecting a host at cannot ping gate way
