Device Pack for 6.1
Answered Question
Jul 25th, 2008
  • Bronze, 100 points or more
Is it possible to install device packs during the 6.X install? I know that you can install SR's during install. any help would be appreciated. Thanks
Jason
Correct Answer by Jaime Valencia about 8 years 10 months ago
no, only SRs or ES can be applied during the install.
javalenc
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Fri, 07/25/2008 - 13:38
  • Cisco Employee,
  • Hall of Fame,
    2011
javalenc
