3750 switch no IOS can't boot
Answered Question
Jul 25th, 2008
Someone deleted the IOS off the switch and power cycled the switch. Now it comes up with the prompt switch: and when I do a dir flash: it does not have an IOS image. How can I copy a image through the console? or can I?
Mike
Correct Answer by Mark Yeates about 8 years 5 months ago
Mike,
You can use xmodem to copy an IOS to the flash using your console cable. It is a pretty simple process, and quick if you change the baud rate to 115200. Here are some step by step instructions for your recovery.
http://www.cisco.com/en/US/products/hw/switches/ps628/products_tech_note09186a0080169696.shtml#topic2
Mark
Overall Rating: 5 (1 ratings)
