Accessing rinter on inside of ASA
Answered Question
Jul 25th, 2008
I have a ASA 5505 with an inside netowk of 10.xx.180.0, and an outside network of xxx.xxx.23.170. Now the ouside server has to be bale to printer to a printer on the inside for daily reports.
should I just nat the inside IP to the a outside IP.
What would be best practise here. I don't want to comprimise inside network?
Can some help me out?
Mike Williams
Overall Rating: 5 (1 ratings)
Farrukh Haroon Sat, 07/26/2008 - 03:11
If it is a newer HP printer, you can use 'Jet-Direct' to connect to the printer using TCP. I think its port 9100.
Farrukh
michael.m.williams Tue, 07/29/2008 - 05:02
I still can't map the printer on the inside interface from the ouside. I added the following statement
static (inside,outside) xxx.xxx.120.103 10.xxx.180.103 netmask 255.255.255.255 tcp 1 0
Then I addedd the ouside server to allow enterance on ouside interface but still can not see it.
I tryied to ping but I alway get denied. Can you ping from a lower security interface to a higher one?
access-list outside_access_in extended permit icmp xxx.xxx.21.0 255.255.255.128 any
Can't get it to work.
Mike
michael.m.williams Tue, 07/29/2008 - 09:07
Here is me config.
Is the security level wrong on my interface? I have 0 on the outside and 100 on the inside. These were the defaults.
thanks
mike
michael.m.williams Wed, 07/30/2008 - 05:04
The server that needs to access the inside printer is
xxx.xxx.23.170 VMS5_Banner witch is part of the Allowed_Out Policy group and here is the acl for that (well I thught it was)
access-list outside_access_in extended permit ip object-group Allowed_Out object-group Allowed_Int
and the inside subnet is part of the Allowed_in.
Did I do it correctly.
Mike
