CUE No Response to Calls
Answered Question
Jul 25th, 2008
My CUE has been working for months. Recently it stops responding to AA and voicemail calls. Debug on cme shows sip invite is sent correctly to cue, by no reponse received.
000567: Jul 26 18:46:46.594: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 202.162.180.9:5060;branch=z9hG4bK455CB
From: "Spare" <sip:[email protected]>;tag=471FF6C-1E48
To: <sip:[email protected]>
Date: Sat, 26 Jul 2008 06:46:46 GMT
Call-ID: [email protected]
Supported: 100rel,timer,resource-priority,replaces
Min-SE: 1800
Cisco-Guid: 1923626420-1511330269-2157967656-3858222332
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SU
tt-triton-cme#BSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1217054806
Contact: <sip:[email protected]:5060>
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 250
v=0
o=CiscoSystemsSIP-GW-UserAgent 2324 9168 IN IP4 202.162.180.9
s=SIP Call
c=IN IP4 202.162.180.9
t=0 0
m=audio 17590 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
Debug on cue shows nothing (not receiving any sip invite).
trace ccn trace ccn stacksip dbug
trace ccn managerappl dbug
trace ccn libmedia dbug
trace ccn subsystemcmt dbug
show trace buffer tail
But VoiceView is working fine.
Any ideas?
Thanks in advance.
Correct Answer by Chad Stachowicz about 8 years 10 months ago
reload the entire router, and verify its still broken. After please upload the config. I am going to suggest a TAC Case though, because equipment does break and if there were 0 changes, and its been working for months. I would firstly assume a broken CUE.
HTH,
Chad
Overall Rating: 5 (1 ratings)
Correct Answer
Chad Stachowicz Sat, 07/26/2008 - 13:37
  • Silver, 250 points or more
HTH,
Chad
bartosz.boczar Thu, 01/15/2009 - 14:27
Larry,
Can you tell what the solution of the problem was? Was it the CME/CUE reload?
Thank you.
Chuan Liu Thu, 01/15/2009 - 14:56
Hi Bartosz,
Just a simple rebooting did the job.
Rgd.
