Router Problems
Jul 26th, 2008
Hi all i am using a 2801 series router with ASA 5520 series firewall behind it and earlier i had 4 Mbps ISP connectivity over serial link and recently it has been changed to 14 Mbps over Ethernet with new Public addresses
And i Changed these things and my router used to work right for 2 hours and then it going to stuck down,i even cannot login to router using telnet and when i reboot it it again works for another 2 hours and finally no connectivity to Internet after 2 hours
I used SDM to know about the processesor usage it raised upto 24% and memory usage is 58%, i am performing PAT over my router is it that causing problem?and all the ports are open in Firewall outside
Suggest me in this regard
sreekanth sarma Sat, 07/26/2008 - 04:55
no not yet i am going to try it tomorrow i want to know whats the reason for the problem
sdoremus33 Sat, 07/26/2008 - 14:23
show processes on the router see what is casuing to spike.
sho processes
sreekanth sarma Sun, 07/27/2008 - 04:42
Hi all it seems that yesterday my ISP had applied no limit over my Link and link utilisation went upto 60 Mbps and where my link or router couldnt manage the traffic flow and stuck down.
Its 2801 with 128 Mb memory and even now when ISP limited it to 14 Mbps the processor usage is 38% ,is it harmful?
