IPCC Express 5.0(2) Creating Documents
Answered Question
Jul 26th, 2008
I'm reading records through a database and am trying to find a way to write data to a temporary location to read back at a later time. Has anyone out there written anything like this?
Any assistance would be appreciated.
Correct Answer by BCOLE2007 about 8 years 7 months ago
Glad to hear this helps
please rate useful posts
Overall Rating: 5 (1 ratings)
BCOLE2007 Sat, 07/26/2008 - 19:20
Hi Rob,
Could I ask why? Is the database down or performance an issue, Also does this need to be held during the call or for a later call?
Blair
RobCal333 Sun, 07/27/2008 - 17:44
The original database would not be down. The data only needs to be held during the call and then discarded. Basically I need to pull a few pieces of information from a database and write it to a temporary document or file so that it can be used later in the same script.
Thanks for your response
BCOLE2007 Mon, 07/28/2008 - 16:37
a few pieces of information... do you mean a couple fields from a select? or do you mean several records from a select? or multiple selects?
Why won't a few variables suffice or have you thought about an Array if several records are needed?
Blair
RobCal333 Mon, 07/28/2008 - 17:24
Thanks Blair, You've just confirmed what I've been thinking all day. I don't believe that there are any limitations to an array.
Have a Great Day!
Correct Answer
BCOLE2007 Tue, 07/29/2008 - 05:24
