MPLS PE/CE routing protocol decision
Jul 26th, 2008
I've to build up a new domestic MPLS network and I'd like to find some guide lines for the best PE/CE routing protocol decision (ie pro, cons, max number of prefix supported, max number of protocol instance config on the PE, example of best config, etc).
I'd like to standardize this protocol decision and config (this is done today in different way by any system engineer configuring the CE..)
Does anybody knows where I can find these info ?
Can anybody answer my question?
Is there a white paper for this topic ?
Tks
Ric
James Lasky Mon, 07/28/2008 - 00:57
Do you have an idea of how many ospf processes (associated to a VRF) are supported in a Cisco 7206VXR acting as PE ?
Tks
Ric
shivlu jain Mon, 07/28/2008 - 01:44
  • Silver, 250 points or more
before 11.0 ios its ws 28 but now a days are unlimited.
regards
shivlu
James Lasky Mon, 07/28/2008 - 01:47
Tks mates!
And what about BGP, RIPv2 ? ISIS ?
pro ?
cons ?
Tks
jon.harald.bovr... Mon, 07/28/2008 - 01:58
ISIS - Not supported as PE-CE routing protocol
RIPv2, BGP and EIGRP runs as address family context and I am not aware of any limitations other than possibly protocol limitations.
Prefer BGP if possible, makes life easier as you not have to redisribute into BGP.
