% No CA root cert exists. Use "ca authenticate"
Jul 26th, 2008
I am trying to configure the PIX to use certificates from a MS CA. I have it working fine with ASA5505 and 5510's but when I try to get it working with a PIX 506E and 501 using 6.3 I get the % No CA root cert exists. Use "ca authenticate", message after the ca enroll command.
Can someone give me a heads up on what I might be doing wrong.
Commands Used:
hostname Pix506e
domain-name nesa.lab
ca generate rsa key 512 (and I also tried 1024)
ca identity ciscoserver.nesa.lab 11.11.11.26
ca configure ciscoserver.nesa.lab ca 1 20 crloptional
ca authenticate ciscoserver.nesa.lab
ca enroll ciscoserver.nesa.lab 8EC4CEAD54268142 serial ipaddress
....and that is where the % No CA root cert exists. Use "ca authenticate" shows up.
Any help is appreciated.
Overall Rating: 5 (1 ratings)
rlewis1951 Sun, 07/27/2008 - 04:52
IX506E(config)# debug crypto ca
PIX506E(config)# ca authenticate ciscoserver.nesa.lab
CI thread sleeps!
Crypto CA thread wakes up!
Certificate has the following attributes:
Fingerprint: 23d6b92b c7eb100f c1294e6b 124b7e75
CRYPTO_PKI: http connection opened
CRYPTO_PKI: transaction GetCACert completed
CRYPTO_PKI: Error: Invalid format for BER encoding while
CRYPTO_PKI: can not set ca cert object.
CRYPTO_PKI: status = 65535: failed to process RA certificate
Crypto CA thread sleeps!
PIX506E(config)# p!
rlewis1951 Sun, 07/27/2008 - 08:48
I changed it and it still does the same thing. I have included the debug for the ca authenicate again.
PIX506E(config)#
PIX506E(config)# ca configure ciscoserver.nesa.lab ra 1 20 crloptional
CI thread sleeps!
msgsym(GETCARACERT, CRYPTO)!
%Error in connection to Certificate Authority: status = FAIL
CRYPTO_PKI: status = 266: failed to verify
PIX506E(config)# ca enroll ciscoserver.nesa.lab F3567C82D9D72346 serial ipaddr$
PIX506E(config)#
PIX506E(config)#
dhananjoy chowdhury Sun, 07/27/2008 - 09:55
  • Silver, 250 points or more
There is problem with the enrollment url in the "ca identity" statement
for your case it should be something like
ca identity ciscoserver.nesa.lab 11.11.11.26:/certsrv/mscep/mscep.dll
the syntax is like this
ca identity :/certsrv/mscep/mscep.dll
Please make this change and check.
Also share the debud and output of "sh run | inc ca identity"
rlewis1951 Sun, 07/27/2008 - 10:24
I made the changes and the following is what happened.
PIX506E(config)# ca zeroize rsa
PIX506E(config)# ca generate rsa key 512
Keypair generation process begin.
.Success.
Insert Selfsigned Certificate:
30 82 01 9f 30 82 01 49 02 20 66 38 61 37 33 30 64 63 35 38
63 65 30 64 33 31 38 65 37 65 62 36 39 30 37 61 66 63 31 61
65 35 30 0d 06 09 2a 86 48 86 f7 0d 01 01 04 05 00 30 4b 31
49 30 0f 06 03 55 04 05 13 08 33 30 32 63 35 61 66 35 30 17
06 03 55 04 03 13 10 50 49 58 35 30 36 45 2e 6e 65 73 61 2e
PIX506E(config)# 09 2a 86 48 86 f7 0d 01 09 02 16 10 50 49
PIX506E(config)# ca identity ciscoserver.nesa.lab 11.11.11.26:/certsrv/mscep/m$
CI thread sleeps!
CRYPTO_PKI: WARNING: A certificate chain could not be constructed while selecting certificate status
Fingerprint: fb4f82b6 d1204e94 d83675a7 4f446c2c
CRYPTO_PKI: Name: EA = [email protected], CN = Cisco2Student, OU = CSAIT, O = XXXXXXXX, L = XXXXXXX, ST = Ontario,
C = CA
C = CA
C = CAPIX50
C = CA
CI thread wakes up!6E(config)# $lab F3567C82D9D72346 serial ipaddress
CI thread sleeps!
% Start certificate enrollment ..
% The subject name in the certificate will be: PIX506E.nesa.lab
% Certificate request sent to Certificate Authority
% The certificate request fingerprint will be displayed.
PIX506E(config)#
CRYPTO_PKI: transaction PKCSReq completed
CRYPTO_PKI: status:
PIX506E(config)# Fingerprint: 437269d6 62eb2a2e 1bd850da 5532ca47
The certificate enrollment request was denied by CA!
CRYPTO_PKI: received msg of 670 bytes
CRYPTO_PKI: WARNING: Certificate, private key or CRL was not found while selecting CRL
CRYPTO_PKI: signed attr: pki-message-type:
13 01 33
CRYPTO_PKI: signed attr: pki-status:
13 01 32
CRYPTO_PKI: signed attr: pki-recipient-nonce:
04 10 9a 66 93 fd ac 8b 9e f1 90 92 fb 18 a1 52 83 bc
CRYPTO_PKI: signed attr: pki-transaction-id:
13 20 66 38 61 37 33 30 64 63 35 38 63 65 30 64 33 31 38 65
37 65 62 36 39 30 37 61 66 63 31 61 65 35
CRYPTO_PKI: status = 101: certificate request is rejected
CRYPTO_PKI: All enrollment requests completed.
PIX506E(config)#
dhananjoy chowdhury Sun, 07/27/2008 - 12:58
Access this link again and get the enrollment challenge password (this expires within 60mins)
http://11.11.11.26/certsrv/mscep
And now on the PIX try ca enroll again with this new password.
After that check the Application logs on the CA server.
Also check whether the time on the pix is correct.
