ASA SSL VPN Not loading XML Parser
Jul 26th, 2008
Setting up a new ASA using SSL VPN with a bookmark to a page that loads various activex components. On PCs that have never been to the site the download of components fails immediately on PCs that have been to the site everything loads but one section saying that "MS XML Parser" failed to load. It says the reason is that user doesn't have admin privileges to install. But running as admin, and it works when connecting to the site from the network.
It's a new ASA install and most things are still on the default, but I see activex and other http related items are set to inherit(enabled).
