Missing something when compiling CPV Java
Jul 26th, 2008
Where and what files do I put where on my PC so that..
import com.audium.server.AudiumException;
import com.audium.server.voiceElement.ActionElementBase;
import com.audium.server.session.ActionElementData;
works, and I can write proper classes for CVP. I think its framework.jar
Any HELP is great!!
Chad
Are you reading "VoiceXML Programming Guide for Cisco Unified Customer Voice Portal Release 4.0(1)" ? That's your bible, along with the Audium Java docs.
On page 4:
"Once a component is constructed in Java, the process for compiling and deploying these classes is very simple. The VoiceXML Server lib directory includes JAR files containing everything a developer requires to compile custom components. The main JAR file of interest is framework.jar, which defines the entire Unified CVP Java API (including the VFCs). To create custom components, all that is needed is to ensure that this JAR file appears in the compiler's CLASSPATH or referred to in a Java IDE project file."
Geoff
