CUCMBE - can't creat unity connection users
Jul 26th, 2008
Brand new CUCMBE system. Can't create a unity user. I get to the dialog to create a user...asks me for the server name and template and then times out and craps out with a java error.
Any ideas?\
Unity answers just fine and ports came up OK, etc. Just can't add folks to it!
Tommer Catlin Sun, 07/27/2008 - 19:41
  • Green, 3000 points or more
Have you added the users to the CUCM side? you have to add users of Unity with First Name Last name, phonoe, associate a line or device. Then go to Unity, Sync users, activate, etc.
If you are having Java problems, restart the Unity connection services or try a different web browser. I just put a CUCMBE in the other day and no java issues.
bpalmquist Tue, 07/29/2008 - 02:03
Turned out that I made a typo in the IP address for the Unity server (on box) in the Applications Servers config of CUCM.
All is well now.
