CVP Application not being found
Jul 26th, 2008
I have uploaded some new application to a new CPV VXML Server. The HelloWorld App works fine, but anything I build and upload is not fine. Is there a version error between my VXML Server and Call Studio poosibly? Anything to check?
Chad
Overall Rating: 5 (1 ratings)
jbyron Sun, 07/27/2008 - 03:16
1. Check the Activity Log and Error Log at C:\Cisco\CVP\VXMLServer\applications\YOURAPP. Is the VXML gateway even getting to your application?
2. Did you restart VXML server or run deployApp.bat for your app?
janet
geoff@hp.com Sun, 07/27/2008 - 07:53
Janet is leading you in the right direction Chad, as would be expected.
The normal procedure with CVP 4.x is:
1. save the application in Studio
2. deploy the app to a local ZIP file on Studio
3. from Ops Console, deploy the ZIP file to the VXML server(s)
4. on each server, run C:\Cisco\CVP\VXMLServer\YOURAPP\admin\deployApp.bat noconfirm
Once you have deployed and are just changing the app, run the same steps but in 4 use updateApp.bat noconfirm.
Geoff
Chad Stachowicz Sun, 07/27/2008 - 08:16
Geoff,
As always your brilliant and have saved me tons of work. Also thanks Janet!!!
Chad
