you could accomplish both if both isp terminate on same router, assume ISP1 interface Ip is 20.20.20.1, ISP2 interface IP 30.30.30.1, inside LAN 192.168.1.0
interface serial0/0
Description ISP1
ip address 20.20.20.1 255.255.255.252
ip nat outside
interface fe0/1
Description ISP2
ip address 30.30.30.1 255.255.255.252
ip nat outside
interface fE0/0
ip nat inside
ip nat pool ISP1 20.20.20.1 20.20.20.1 netmask 255.255.255.252
ip nat pool ISP2 30.30.30.1 30.30.30.1 netmask 255.255.255.252
ip nat inside source route-map ISP1 pool ISP1 overload
ip nat inside source route-map ISP2 pool ISP2 overload
ip access-list standard localLAN
permit 192.168.1.0 0.0.0.255
route-map ISP1
match ip address localLAN
match interface s0/0
route-map ISP2
match interface fe0/1
ip route 0.0.0.0 0.0.0.0 20.20.20.2 <- ISP1 next hop router interface ip
ip route 0.0.0.0 0.0.0.0 30.30.30.2 <- ISP2 next hop router interface ip
Jorge
Jorge Rodriguez
