PEAP requirements
Answered Question
Jul 27th, 2008
Hi Guru's
I have a quick question, is the user PC need to be join first in domain so the ACS will validate the CA?
Correct Answer by zhenningx about 8 years 12 months ago
This link explains why you need machine authentication and why PEAP requires PC joined domain:
http://articles.techrepublic.com.com/5100-10878_11-6148574.html
Hope it helps!
Zhenningx
Overall Rating: 5 (2 ratings)
zhenningx Mon, 07/28/2008 - 18:24
  • Bronze, 100 points or more
If the user needs to log into the domain, the PC need to join in domain first and you need to use machine authentication.
jong_r0602 Tue, 07/29/2008 - 08:40
thanks for the reply. May i know also the reason why?
Many Thanks,
Jong
