Match unknown number with analoge FXO interface
Jul 27th, 2008
Hi There,
I tried to make a incoming dial-peer what matches a unknown number with my callmanager express router.
I have an FXO interface and this one is connected to a analoge provider line,however its not sending its own number over the line so i cannot match with the incoming dail-peer..
Does anyone have a solution for this?
Can i match every number that is coming inside..?
Overall Rating: 5 (1 ratings)
Marwan ALshawi Sun, 07/27/2008 - 22:12
try the following command in your incoming dial-peer
incoming called-number .
dont forget the dot
this will make what is called defaul- incomeing dial-peer
good luck
Rate,if helpful
kennis1977 Mon, 07/28/2008 - 06:22
ah ok..going to tried that...
and can i use this dot also for my translation-profile ?
because my phonenumber is 100
and how does it look like then (the translation-profile?)
Marwan ALshawi Mon, 07/28/2008 - 17:59
what you wanna achive with the translation profile?
and what numbers you have ?
post the details to let me help you ok
kennis1977 Mon, 07/28/2008 - 23:47
I have an analoge line with number 0101234567
for example..
however this number is ending at 567 and my number internal is 100
so if we can match with the dot its not letting number 100 to ring
So thats wy i think we also need a translation-profile that is pointing the dot to 100
But..perhaps can you also give me the complete incoming dial-peer that would be great!
so the only thing i want to do is let the phone ring when someone is calling the external number.
hope you can help me..
Gr
Marwan ALshawi Tue, 07/29/2008 - 03:48
the following config will take any number coming the port such as 0/0/1 ISDN and change the called number to 100
so if u have a dial-peer for a number 100
such as pots for analog phon or voip
the call will be forwarded to that dial-peer
Voice translation-rule 1
Rule 1 /.*/ /100/
Voice translation-profile profile1
Translated called 1
Dial-peer voice 9 pots
Incoming called-number .
direct-inward-dial
translation-profile incoming profile1
port 0/0/1
forward-digits all
but if you have FXO ( which your case FXO i think)
just put the following command under the FXO port
and it will forward the call to the number 100
voice-port 1/0/0
connection plar opx 100
PSTN calls arriving on the FXO port can now terminate on extension 100
(replace the port 1/0/0 with your own port )
any try it and let me know
Marwan ALshawi Tue, 07/29/2008 - 05:48
focus on this one:
voice-port 1/0/0
dont forget to make pots dial-peer for ur analog phone such as
dial-peer voice 3 pots
destination-pattren 100
port 1/0/1
where the port is ur FXS analog phone port
let me know if its worked or not
kennis1977 Tue, 07/29/2008 - 07:09
Great!!!
The last config worked..
with the plax connection...
the dial-peer incoming didn't worked..
so this is then very easy with only one command...
however normally the dial-peer must work but then we need a number to match...but tis is great... thank you...
Marwan ALshawi Tue, 07/29/2008 - 07:12
i confused first time
with FXO only the command i have given you work
but if u have trunk or an ISDN link then the incoming dial-peer condig should be use
any way i am glad its working
please Rate the helpful post
and good luck
kennis1977 Tue, 07/29/2008 - 07:14
Yep...great..
thank you for your help..
and i rate you reply...
