FWSM 6500- pinging VLAN interface
Answered Question
Jul 27th, 2008
I have FWSM module installed in 6509e catalyst switch. I have configured 2 vlans as follows.
HR VLAN ID 16--- Gateway----X.X.16.1
Management VLAN ID 18 Gateway---X.X.18.1
i am trying to ping from host in 16 vlan to a host in 18 vlan which is successful but i cant ping 18 vlan gateway which is X.X.18.1. why it is so?
please reply.
Correct Answer by Farrukh Haroon about 8 years 10 months ago
OK thats great, please rate if helpful.
Farrukh
Overall Rating: 3 (1 ratings)
Marwan ALshawi Fri, 08/01/2008 - 18:01
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
check the following
1 ACLs in both direction because FWSM not like ASA regardless the security level u have u need to make ACL to permit traffic to flow by default evrything is denied
secondly
eable icmp and icmp error inspection
also make sure u have the right VLANs assigned to the FWSM, ports and client
finally make sure the client has the right default gateway
good luck
please if helpful Rate
Farrukh Haroon Sat, 08/02/2008 - 12:17
  • Red, 2250 points or more
Ahmad, are you trying to ping from a 'host' in the vlan 16 subnet to the FWSM's Vlan 18 SVI (Gateway interface)?
If so, I'm afraid this will not work. The FWSM/ASA/PIX do not allow pinging any of its interfaces UNLESS you are part of the same interface subnet/zone. For example Vlan 16 users can only ping -X.X.16.1 and NOT -X.X.18.1 and similarly Vlan 18 users can only ping -X.X.18.1.
Farrukh
ahmad-sajjad Mon, 08/04/2008 - 21:42
Gentlemen!
Thanks alot for your replies, i am going to enable icmp error on the fwsm to make sure about the ping.
Farrukh
someone told me that FWSM will not allow to ping from one vlan to the other vlan gateway. in my case,
it is a host in X.X.16.X vlan can ping its own gateway which is X.X.16.1 and can also ping host in X.X.18.X vlan but cant ping X.X.18.1 which is the gateway for vlan 18. What is the logic, y it cant ping.
Farrukh Haroon Mon, 08/04/2008 - 21:55
As I told you this is one of the 'rules' of FWSM/ASA/PIX. Perhaps they did this to prevent 'mapping' of zones or something, personally I find it very annoying.
You will 'not' be able to ping X.X.18.1 from ANY machine in the X.X.16.X zone. Please check my previous post also, I said the same things.
Farrukh
Marwan ALshawi Sat, 08/02/2008 - 18:58
in addition
if u wanna try to ping any cisco firewall interface from other interface u will not be able
but as long as u ping the clients behind that interface
so u your configurations if fine
and nothing to worry about
good luck
please, rate if helpful
ahmad-sajjad Thu, 08/07/2008 - 14:00
Thanks everyone! I think it was quite helpful.
Sajjad
Marwan ALshawi Thu, 08/07/2008 - 16:22
u welcome
please, rate the helpful post
Correct Answer
Farrukh Haroon Thu, 08/07/2008 - 23:30
Farrukh
