single switch and stp
Answered Question
Jul 27th, 2008
hi every body!
I just want to know if:
we have one switch and we connect fo/1 of the switch to f0/2 of the same switch,assuming stp is enabled,Will f0/1 would be designated port or rootport?
thanks a lot !
Correct Answer by ssieger about 8 years 5 months ago
maybe some switches behave differently, but on a 3560G the only thing that happens is that port f0/2 is blocking, f0/1 ist in forwarding state because of its lower mac-address. but you won't see that port f0/1 has become a reals root port, it's only forwarding.
greetings, Stephan
Correct Answer by Edison Ortiz about 8 years 5 months ago
A loop will be detected and the port will be shutdown.
__
Edison.
Overall Rating: 5 (2 ratings)
Correct Answer
Edison Ortiz Sun, 07/27/2008 - 19:31
__
Edison.
Correct Answer
ssieger Mon, 07/28/2008 - 02:00
greetings, Stephan
