Called id not displaying on SIP trunk
Jul 27th, 2008
I ve a SIP trunk to CME.
When I call from CME to CM ,i can see "to called name";for example "to Ahmed"
BUT
the opposite not like that;i can see "to 1000"
NO name is displying even after call is estaplished.
I put the following parameters to allowed on SIP trunk on inbound & outbound calls:
Connected Line ID Presentation*
Connected Name Presentation*
I need to display on caller LCD screen "to called name"
Chad Stachowicz Sun, 07/27/2008 - 21:13
yousseff,
The alerting name is a field that is local and used within the CCM, once you go out to a CME or intercluster, they aren't going to work. You need to setup directory services in CME using the 'directory entry' command on the side of the CME. It's a pain, but its the best I know how.
HTH, please rate useful posts.
Chad
youssef.ahmed Tue, 07/29/2008 - 11:32
Hi Chad,
But why it is working if i make a h323 trunk to CME through GK??
Actually I can't got yuor point regarding "directory entry" in CME.
Plz describe in more details.
Thx
