jar file shared accross multiple CVP applications
Jul 27th, 2008
  • Silver, 250 points or more
Guys,
What is the appropriate directory if a JAR files is servicing multiple Applications... I tried C:\Cisco\CVP\VXMLServer\lib but it says its not a valid action element class.
Thanks all!
Chad
Overall Rating: 5 (1 ratings)
jbyron Sun, 07/27/2008 - 15:28
Try C:\Cisco\CVP\VXMLServer\common\lib
Yep.
Chad,
VoiceXML Server User Guide for Cisco Unified Customer Voice Portal. Appendix B: The Directory Structure, page 104.
"Folder common:
This folder contains the Java classes and JAR files shared across all voice applications hosted on the VoiceXML Server. Individual Java classes go in the classes directory and JAR files go in the lib directory."
Geoff
Chad Stachowicz Sun, 07/27/2008 - 21:31
Thanks much guys, worked like a charm first try, that cleaned up some unneeded clutter!
Chad
