NAC and nessus plugin
Jul 27th, 2008
  • Bronze, 100 points or more
On 4.1.3.2 and went to
http://www.nessus.org/download/index.php
and download
nessus-plugins-2.2.11.tar.gz (7468 KB)
nessus-plugins-GPL-2.2.11.tar.gz (1071 KB)
renamed the 1st one to "plugins.tar.gz" and was able to upload the plugin successfully but when I try to apply plugins by selecting "-All-" nothing shows up. I delete the plugins and upload again - same problem. I restart by CAM and CAS and still a problem
How do I get the plugins to show up?
Overall Rating: 5 (1 ratings)
igor.florek Wed, 07/30/2008 - 02:42
I don't know where did you get those files, but this what I did:
Registered myself here:
http://www.nessus.org/plugins/index.php?view=register
In mail recieved as a response clicked:
http://plugins.nessus.org/manual-register.php
which let's you download all plugins (file all-2.0.tar.gz). That unfortunately can't be uploaded into CAM as is because it's larger than max. upload limit. You have to extract it, split into parts smaller than 10MB and compress again to plugins.tar.gz (7zip can be used for this)
After that, you can upload/import 2 files produced into CAM and it should work ... it worked for me ;)
